spark diode
发表于 2021-9-1 00:44:12 | 显示全部楼层 |阅读模式
On my lincoln welders, I25, 225 Lincoln weldenpower. both ac and dc, the welder won't start welding untill I touch a wire to the battery hot wire.I have done this several times but I forgot exactly what I did to get the power from the armiture.I am aware of the spark diode that automaticly starts the machine welding,but I forgot how, or what to jump to get it going.can somebody give me some suggestions on this problem.
Reply:Welcome to the forum bwbitt.What you're describing is actually referred to as 'flashing the field' (and I don't mean to plant a vision of trench coats and bare legs in your head).You have to do this every time you use the welder?  If so, there are a number of reasons why you would have to do this that are easy to check out.  Your unit code number would held to assure having the correct wiring schematic to use in troubleshooting but basically the main causes could be:1) Flashing circuit fuse blown2) Flashing diode failed open3) No charging output from the engine alternatorLast edited by duaneb55; 08-08-2009 at 02:16 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanx for the info:I don't mind (that's Ok wid me) jumping the flashing curcuit.I have done it before but I forgot how I did what i did.Sooooooo my question is how did I jump the flashing curcuit.both of my weldenpowers hav to be jumped to start welding,
Reply:12vdc(+) momentarily to the positive brush circuit (typically the red and/or blue wire or outer brush).Do you have your unit manual to refer to?  If not, you can plug its code number in here http://www.mylincolnelectric.com/Cat...ualsearch.aspx and download it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanx Duane:I'm am sure this is the exact info I needed, keep up the good workyour frend Boone Doggie
Reply:I want to give this a try, Let ya know what happens thanx again
GMT+8, 2025-12-20 20:32 , Processed in 0.095132 second(s), 18 queries .
