Tig terminology?
发表于 2021-9-1 00:44:11 | 显示全部楼层 |阅读模式
As I do not tig everyday and may be showing my ???. When the term walking the cup is used does it mean that the cup touches the metal ?  Thanks Jim
Reply:Do a quick search here or on Utube for the term "walking the cup".  It's been explained before, and a video from U-tube will make more sense than most written explanations.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:One question on "walking the cup".Can I use this technique with my roto head tig torch?The youtube vids show no roto heads being used for walking the cup.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:...Learn something new everyday.  I've never seen a roto head TIG torch.  But a quick search on google turned one up.  What a crazy idea.  I don't see why you couldn't use a roto head torch and cup walking technique.  I'd have to use one for a while to guess if it would help or just get in the way.Try it and tell us what you think... Originally Posted by snoeproeOne question on "walking the cup".Can I use this technique with my roto head tig torch?The youtube vids show no roto heads being used for walking the cup.
Reply:Roto-head torch. Real cool
Reply:This is my torch.http://www.ckworldwide.com/flex-loc.htmUpon review, it is recommended for "cup walking".Time to give it a try.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:You could try it, but I could see it becoming more of a hindrance than helpful as you come around the top of the pipe because of the fixed angle on the handle.
GMT+8, 2025-12-20 20:31 , Processed in 0.095006 second(s), 18 queries .
