Semi overhead welding
发表于 2021-9-1 00:44:03 | 显示全部楼层 |阅读模式
I could not find the answer I was looking for when I did a search so I thought I would try here.I am wanting to find tips for overhead welding with a mig.  What I am doing is welding a piece of 5/8 flat bar to an upright post as a hinge brace.  When I am welding the weld on the underside I am having problems with keeping the weld somewhat flat.  Now I know that gravity is working in my favor  and I will not have a completely flat weld.  I am just trying to get the proper penetration without having my weld droop down so much.Any suggestions?Thank you, BoLast edited by TXweldor; 08-18-2009 at 06:13 PM.
Reply:One of my tricks on overhead welding is to"v" the metal. On both sides if possible that way the weld extends or penetrates to the opposite side offering a foothold as you weld.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
GMT+8, 2025-12-20 19:06 , Processed in 0.107854 second(s), 18 queries .
