Can this cracked exhaust pipe be welded?
发表于 2021-9-1 00:44:01 | 显示全部楼层 |阅读模式
Hello, I was referred here by a fellow member at MercedesShop.com when I posted a photo of a crack in my exhaust pipe, where it meets the center muffler.  A photo is attached.  As you can see, the crack is on the existing weld.  It is relatively fresh, the result of my tailpipe hangars breaking, causing the exhaust to flex (and support its own weight), and the crack to form.  The rust you see is superficial,and  the dark residue on the lower portion of the muffler is blown-back oil from previous leak.  Thanks for your attention and any feedback you provide will be appreciated. Attached Images
Reply:Looks pretty rotted from where I'm sitting.  Maybe it could be sleeved or something, but it's only a matter of time I'm afraid.www.lindgrensupercars.comMiller Dynasty 350Miller Dynasty 200DX - retiredMiller Millermatic 210Miller Spectrum 3080Miller "Power of Blue" stool  Miller Syncrowave 180SD - retired
Reply:Originally Posted by kjlindgrLooks pretty rotted from where I'm sitting.  Maybe it could be sleeved or something, but it's only a matter of time I'm afraid.
Reply:I think thar if you want it fixed for a long time, put on a new one.   Sleves etc have a very linited lift.keith The older the boys, the more expensive the TOYS!!Previous owned;Linde 300 Amp welderMiller Gas drv welder, Tumbstone,Dayton Miller ac to dc converter,High frequency unitLongevity LS60PCurrrently owned;Longevity WeldAll 200PI
Reply:If you can get the metal to clean up shiny and have enough metal left I would say yes. If it is for an old clunker I would not put alot of money into the thing.
Reply:Just for S&G's.  Go out an price the "right" fix on a modern exhaust system where the convertor is.  It generally is a solid setup from manifold to muffler.It is ONE HECK OF AN EXPENSIVE PROPOSITION (aw crap, now I'm yellin')Maybe near 3-6 C notes.  Aftermarket convertors, cobbled in, are generally the only cost effective alternative.Or trade the car in every few years"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Yes it can be welded IF the mig gun fits in there.  It would be better to cut the pipe off with a sawzall, install a short piece and weld it to the muffler and the pipe.  I do a lot of em.If it has to come off the car, its a bigger job of course.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Thanks to everyone for your feedback.  It looks like I'm looking at a sleeve or a replacement.
GMT+8, 2025-12-20 20:21 , Processed in 0.094832 second(s), 18 queries .
