is this home made or can you buy one?
发表于 2021-9-1 00:43:59 | 显示全部楼层 |阅读模式
is this home made or can you buy one? im looking for a bed i like the looks of this one Attached Images
Reply:http://www.bobkingstruckbeds.com
Reply:Attached Images
Reply:It looks very nice, whatever it's origins are.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Home built, but built good.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Hello aslippy, if you follow the link that rmkrider1 supplied you will see that there are a number of different bed types available. In the wonderful world of field welding and service there are a great number of different applications of trucks and equipment and most of them are specific to certain geological areas as well as applications. I believe the bed on the truck that you included pictures of is mainly a pipeliner type of application. If this is the sort of work that you are going to go after then this is likely right up your alley for purpose and use. If you have other types of work or applications in mind you might want to spell those out and a lot of folks on the forum can likely give you ideas for the types and layouts of truck beds that might serve your purposes best. In my area a great number of portable rigs are involved with heavy construction and logging and as such they have service cranes, large portable welders, onboard air compressors, lighting and power generation capabilities, large hand tool selections, parts inventories, jacking capabilities, and other associated capabilities to service large construction and logging equipment. This would differ from many other types of services and areas that you might run into if you lived in a petrochemical area or oilfield type environment. You likely get the idea. Just a bit more for you to consider. Best regards, Allanaevald
GMT+8, 2025-12-20 20:20 , Processed in 0.090736 second(s), 18 queries .
