Not getting gas to my tip of my MIG?
发表于 2021-9-1 00:43:57 | 显示全部楼层 |阅读模式
Newbie here so take it easy   I'm welding with a Lincoln "handy mig"  Im using .030" wire with C25 gas.  It has worked very good for me until recently.  My welds seam like they are not getting any gas to the puddle?  Like i have the tank off... Its not off, and there is PLENTY of gas...  I use a regulator with the guages, then i switched regulators to the one that came with the kit, thinking that there could be something wrong with the regulator.  Nope same result?  My Manual does not go that deep into trouble shooting.  It seams like a solonoid is not opening or blocked line?Any help would be great!Thanks  Ken p.s.  On a different note, does it seam odd that i have to use a different heat range welding with Flux core and Solid core (flux core colder)?    Same metal
Reply:I had a problem with a Lincoln mig 180. I found I didn't have the liner conduit ( the part that holds the liner) plugged into the machine right. You have to seat it pretty hard because it has a piece to keep the gas from leaking. If this is not it, take out your wire and take the conduit out of the machine. Then power it up and pull the trigger with your finger in the hole. If you don't have gas work you way back. I would be willing to bet it is not plugged in far enough though.
Reply:pull your gun from the feeder but leave the wire hooked up ,turn on gas and see if its reaching your gun,should hear the gas hissing where your gun plugs in when you pull the trigger.If you have gas could be the diffuser is clogged with spray or the gas feed in your gun cable could be blocked.if not check where your line comes out of the gas solenoid ,if not it is likely your solenoid.other than that check for loose wires on the solenoid .If nothing it is likely a bad board,time for a new welder or used partsfelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Gosh i hope that its not the welder, i bought a quality brand so that i would not have too many issues!  thanks
Reply:[QUOTE=p.s.  On a different note, does it seam odd that i have to use a different heat range welding with Flux core and Solid core (flux core colder)?    Same metal[/QUOTE]That's normal.  You should be switching the polarity for FC and solid, and you will generally get deeper penetration with the flux core.  So, it will appear that the FC is running hotter at any given setting.  Does that make sense?Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Yes that makes sense.  Oh ive never switched polarity for flux and solid?!  I wonder if that would give me better Penetration with Solid core?
Reply:Originally Posted by KENLUDE97Yes that makes sense.  Oh ive never switched polarity for flux and solid?!  I wonder if that would give me better Penetration with Solid core?
Reply:Yes i think that i can.  Ive noticed the wires there and wondered why they were so accessable?  I figured for service?  I do not remember reading about it when i got the welder but i sure will be tonight when i get home!  Thanks.
Reply:Fluxcore is DCEN (torch on negative electrode) and solid wire with gas is DCEP (torch on positive electrode).Last edited by Craig in Denver; 08-25-2009 at 03:49 PM.9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Originally Posted by Leadhead1911  On some machines you can't change the polarity.
GMT+8, 2025-12-20 21:21 , Processed in 0.110211 second(s), 19 queries .
