the most difficult to weld in accordance with BS EN 287?
发表于 2021-9-1 00:43:53 | 显示全部楼层 |阅读模式
Hi every onewhich of the following butt welds would be considered the most difficult to weld in accordance with BS EN 287?1. Single V butt2. double V butt welded both side3. single U butt with backing strip4. assymetrical double V butt-welded both side
Reply:Uhhhhmm....  I'd like to buy a vowel!Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Maybe you should explain to us what BC EN 287 is. You are making the assumption that we know what standards and procedures the European Union has. Just for fun I am going to pick 4.
Reply:Sounds like answers on a written test question.   I'll go with number 4 as well.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:#4 is the  answer because of the preparation that goes into the weld. Used on 3/4" or greater metal and very difficult when joining multiple seams together. You see this done in pressure valves that must stand up to alot of constant stress. Attached ImagesCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:I'm going with #3, something about, "...butt with a backing strip", gets to me! Rex
Reply:Nah that only happens if your in jail and drop the soap in the showerCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by specterNah that only happens if your in jail and drop the soap in the shower
Reply:neither have I ! But you sure hear of it happening on those TV shows and movies.I see Herzany never came back to give the answer or elaborate on his question.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
GMT+8, 2025-12-20 21:44 , Processed in 0.103073 second(s), 18 queries .
