sleeve bearings
发表于 2021-9-1 00:43:53 | 显示全部楼层 |阅读模式
I'm need to make one part slide up and down on another part.  I'm going to use a sleeve bearing on a shoulder bolt to accomplish this.  Here is a picture Should I use a thrust washer on each side of the sleeve bearing so the head of the bolt and the nut that keeps the sleeve bearing in place don't restrict the sleeve bearing from turning?  Or how else would I keep the sleeve bearing in place on the shoulder bolt without restricting the bearing? Thanks, Scott
Reply:Nylock or double nuts.  Keep the tension low on the sleeveVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by DualieNylock or double nuts.  Keep the tension low on the sleeve
GMT+8, 2025-12-20 20:27 , Processed in 0.090588 second(s), 18 queries .
