Millermatic 10a
发表于 2021-9-1 00:43:51 | 显示全部楼层 |阅读模式
I just got a millermatic 10a to put on my miller dialarc hf.  Never used one before so I have a few questions about hooking it up. I figure that you just take the positive lead from the powersource to the lead on my cable to my gun on the wire feeder.  And just use the ground on the power source to the work being welded. I know this is a stupid question but do you use the wire feeder as ac or dc.  I would appreciate any help you guys give me.
Reply:I was told the dialarc had a wire feeder on it before I got it.  The wire feeder I jsut got has a 110v receptacle on it already to plug in the wall.  I had a nice lincoln powermig255 but it got stolen and I just dont have the money to replace it right  now so I need to find a way to make this work.  The one question I realy have is there is a lead attached to the end of the gun by the rollers which lead do I need to attach this to.
Reply:It looks just like that but single roll.  My dialarc is 230v single phase if it makes a difference
Reply:I hate to seem like a total idiot but could you explain why my dialarc wont work.  I have seen them on other dialarc's before and they seem to work fine.  I'm not trying to be a wiseass so please dont take it that way i'm just rying to understand what I'm dealing with.  the model off my welder is dialarc 250 hf-pThanks for all the info.
Reply:Ironhead (dang good handle),Listen to what 7A749's trying to tell you (in a polite way).NOT GONNA WORK.The Dialarc HF is a great stick welder and a marginal tig machine (outdated for tig), but it was never designed as a power source for a wirefeeder and as such, it flat out stinks.Much as you'd like to hear different, that's the facts.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:7A749 said "The first machine is a 1979 Miller SCP 200C single phase MIG machine with an S 54A Miller wire feeder on it."And the only reason you posted the picture is because you want me to buy it and you knew I would be sitting here drooling over it.FelonLast edited by Felonyass Monk; 08-25-2009 at 11:31 AM.Caution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Originally Posted by Felonyass Monk7A749 said "The first machine is a 1979 Miller SCP 200C single phase MIG machine with an S 54A Miller wire feeder on it."And the only reason you posted the picture is because you want me to buy it and you knew I would be sitting here drooling over it.Felon
Reply:So how much can I expect to pay for a mig machine to run the wire feeder?
Reply:Sorry, Felon.That machine has been gone for about 4+ years. I still have the cart tho....Its just as well ,the wife would probably leave if i bought another welder,!on second thought.....Relatively speaking, MIG machines have gotten simpler and way more affordable to the average Joe than they were back then. Simpler to use but a helluva lot more complicated ,oh well the progress of man....Felon Caution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Will a miller xmt 304 run this wire feeder?
Reply:How well will the Miller regency 200 cv-dc run it?  I found one that I think I can get pretty cheap.
Reply:I can get the regency for $300 and I found a xmt300 with autolink and digital inverter for $500
Reply:I just found out the regency comes with a spool gun also not sure what model but it does have one.
Reply:$300 for any mig with a spool gun included is a good deal. I paid $300 for my old CP250TS with an XR feeder and XR15A push-pull gun.   I couldn't use the CP without 3-phase power so I sold it for $200 in a matter of hours after posting the ad and kept the XR feeder and gun.  Converted the XR gun into a spool gun with parts from a Spoolmatic and took the Python off one of my Cobramatics that blew a board to use on the XR feeder.   Best $100 I ever spent!  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:thanksguys for all the advice.  sorry if I started the thread a litte ignorant about things.  I'm going to buy the regency tomorrow.  Now all I have to do is figure out what control cord I need to run my 10a feeder off of the regency.
Reply:You should be able to use the same cable and change the connector on the end of it.   You got 2 seperate connectors on there now right, one for contactor and one for the motor power?   So cut both off and wire the one connector that matches the Regency in their place.   You need a wiring diagram for both the feeder and the regency.   Go to the online owner's manuals section and download the .pdf's for each machine so you know where to put the wires once you find the connector.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:The guy jsut called me and dropped the price on the xmt300 now I dont know what to do. I like the idea of the xmt being able to stick mig and tig mild steel. PLus the guy sent me pics of the regency and it looks a little rough he said it was about 20 yrs old.  The xmt looks like new and is only 7 years old.the more I think about it the more I dont know what to do.
Reply:I would think that Arc Products should be able to work on the XMT 300 if it is the plastic case model like the PowCon.  They are the prime service center for all things PowCon.   The XMT 300's existence was made possible by Miller's purchase of PowCon's technology and designs and they share some similarities, if it is the top & bottom plastic case model with the big seam around the beltline.I would go for the XMT.  I have a PowCon 300SM and it is a very good machine.  Mine is constant-voltage only, but PowCon made cc/cv models too with all the same features as my XMT 304.  So yeah, I'm partial to PowCons and XMT's.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Well I'm just e-mailed the guy and I'm going to buy the regency tomorrow.  So I guess now I need to get the connector to wire it up.  The guy had the plug in the back of the wire feeder wired up so he could just plug it into the wall I know this is not right but will it work for now.
GMT+8, 2025-12-20 20:27 , Processed in 0.092436 second(s), 18 queries .
