Making Jigs
发表于 2021-9-1 00:43:49 | 显示全部楼层 |阅读模式
I am making some jigs for an exhaust(car) and I need to know what the pieces that will hold up or support the pipe in the jig are called. The exhaust is 3" OD and the pieces that will support the pipe are shaped in  a U. I've googled just about every possible name I can think of and no luck.ThanksLast edited by coachk; 08-31-2009 at 06:06 PM.
Reply:Saddles,  maybe ??MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:hanger (ar)
Reply:Originally Posted by Chris Barhanger (ar)
Reply:Originally Posted by coachkI am making some jigs for an exhaust(car) and I need to know what the pieces that will hold up or support the pipe in the jig are called. The exhaust is 3" OD and the pieces that will support the pipe are shaped in  a U. I've googled just about every possible name I can think of and no luck.Thanks
GMT+8, 2025-12-20 21:18 , Processed in 0.071556 second(s), 18 queries .
