work bench
发表于 2021-9-1 00:43:43 | 显示全部楼层 |阅读模式
another bench Attached Images
Reply:StickyNice looking bench. Is your shop sided with steel panels?
Reply:Scott,Yes it is.  And VERY cold this time of the year.
Reply:Some steel studs and homosote will do a lot to minimize that cold thing.  Then you  can build a stove, and fuel it with scrap wood, and enjoy a warm shop.Even steel walls beat hell out of being out in the wind.  4 degrees here right now.Appreciation Gains You Recognition-
Reply:Sticky,We are also in a deep freeze here to, with alot of wind. Not supposed to moderate till Sat.
GMT+8, 2025-12-20 21:49 , Processed in 0.124960 second(s), 18 queries .
