SB Motor mounts
发表于 2021-9-1 00:43:42 | 显示全部楼层 |阅读模式
These were the first thing (of use) that I ever made-smaw.  "after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:What do they go to?
Reply:Originally posted by Scott S What do they go to?
Reply:can you give any specs on the f250 bushings (id/od and overall length)?  I've seen similar done with Jeep YJ spring bushings, but they can get pricey kinda quick.  guess my point is I'm looking for an inexpensive bushing to use in this type of application....  motor mounts, cage mounts, trans crossmember, etc for the project I posted about on my Jeep frame.cool mounts, BTW......Chad-
Reply:Originally posted by chumly2071 can you give any specs on the f250 bushings (id/od and overall length)?  I've seen similar done with Jeep YJ spring bushings, but they can get pricey kinda quick.  guess my point is I'm looking for an inexpensive bushing to use in this type of application....  motor mounts, cage mounts, trans crossmember, etc for the project I posted about on my Jeep frame.cool mounts, BTW......Chad-
GMT+8, 2025-12-20 19:59 , Processed in 0.093958 second(s), 18 queries .
