My first big project
发表于 2021-9-1 00:43:32 | 显示全部楼层 |阅读模式
I started building my garage/shop back in July 2003. Its 30'x30'garage, then i decided while i was at it might as well add an 18'x18' shop area. Now then take in mind only tools used in building this thing was a bobcat225, 41/2 angle grinder, cordless drill, cuttin torch, and a ladder, 1 son, and a lot of sweat and a tiny bit of blood.
Reply:Shoot ok pic didn't post will see what i can do to get it to the right size
Reply:ok i give up right now, says its too big and changed size but still ain't workin lol need cuttin torch i guess to get it to right size.gotta play with attachments and figure out what the hell i'm doin wrong
Reply:tryin again Attached Images
Reply:thanks to cutter i got one of em posted still ain't figured out what i am doing wrong lol
Reply:another pic Attached Images
Reply:#3 Attached Images
Reply:a cheap cuttin table Attached Images
Reply:had some expanded metal laying around so i made it into peg board for hanging mis. tools Attached Images
Reply:thanks cutter it was the jpeg,gif thing messing me up
Reply:Originally posted by rodburner thanks cutter it was the jpeg,gif thing messing me up
Reply:thanks cutter not to metion they will load alot faster too lol i will get it figured out and will make em smaller
Reply:ok here is last pic, i just took this today still like puttin in garage doors. And its snowin outside yucckkkkkkkkkk Attached Images
Reply:Billy, it appears you have a considerable span on the sheet metal, so I'm figurin you don't see a lot of snow accumulation.In this part of the country, 4 feet of span is pushin your luck on metal roofing.Do you have serious wind considerations where you are, or don't you have to worry about that either?Appreciation Gains You Recognition-
Reply:well we don't get much snow down here franz except for today. and yes we get lot of wind. i did place em a bit too far apart. but it has already withstood 50mph straight winds into it, i am going to add more perlin to it cause after i finished it i knew i screwed up. may be a tad harder to put under tin but i think i can get it done. all the frame work is made outta 2 3/8  oilfield tubing which is about .190wallLast edited by rodburner; 01-18-2004 at 01:26 PM.
Reply:well iot looks good from Alabama.so i'mnot saying nothing except good job!!!  maybe one day ill place a few here myself!!
Reply:no time like the present 7018
Reply:A toast to a job well done! I would not have thought to store my gasoline under my chop saw, but I don't have a all steel building either, just kidding,
Reply:Lol yea i don't store em there either thats where they ended up when i emptied em and ain't put em back in truck to fill back up, i for sure don't cut with em under there lol, might not have a shop to work in
Reply:Hey rodburner, you mentioned garage doors don't know where Merkel is but if your close to the red river you might drive up to Madill OK a place called J&I Manufacturing I bought a 8'x10" ($289) and a 10x10 ($309) for my shop this past weekend. BTW they are roll-up doors. Nice lookin work shop.Still lookin for Rock!
Reply:thanks Alden, been pondering on which type doors i wanted, never hung garage doors before but am leaning towards roll up type, and i'm about 3hr drive just to the red river. I have access to a metal building facility bout an hr away and they have a 10'x8' roll up for 236, haven't checked it out to see if its worth that yet, but thanks for the info,will keep it in mind.
GMT+8, 2025-12-21 08:12 , Processed in 0.094104 second(s), 18 queries .
