Time to start some projects!
发表于 2021-9-1 00:43:32 | 显示全部楼层 |阅读模式
Well The warm days I spent finishing the Mower shed. Attached Images
Reply:Then I had to tackle the shop mess. Attached Images
Reply:Did the sifting sorting gig.  Threw away useless stuff I had been saving. Attached Images
Reply:Took me several days to get the air compressor up and running. Attached Images
Reply:I am going to start with restoring that steering sled against the bench.  #1 son wants one really bad.  It is held together with rivets and has a lot of slip joints.  I don't know if I can find the replacement rivets so I think I will use 1/8" round stock and TIG washers on the end.  Has only snowed here once so maybe I can finish before next snow. Attached Images
Reply:An oxygen acetylene cart would fit right next to the tig welder  Seriously Nice looking shop. I wish I had the room
Reply:As best I can see it, even with the trifocular goggles, it appears to be a Flexible Flyer.If so, don't forget to parafin the boarde where they slip thru the frame to eliminate binding in the turns.  Those things were great downhill, but a real letdown on the uphill drag.Appreciation Gains You Recognition-
Reply:Well I found out real quick that I need a light in that sandblaster.  I Can't see chit.  Fla Jim  I knew that was comming!
Reply:Good looking shop, way too neat but nice .
Reply:Would you prefer this. Attached Images
Reply:LOL, that looks more familiar.
Reply:so your telling me my shop could be that clean mine looks almost like the last pic come on down here to tovey and show me how you did that
Reply:Hello all. Enjoy reading all the threads. Learned a lot already. In the process up getting back into welding projects. My wife says 1grnlwn's before picture is still a lot neater than my garage. Short term thing until new shop is done. If you all can stand some more pictures, I'll post some before, during, and during.After never seems to get here.
Reply:1grnlwn- Nice shop! I'll bet you can't keep it that neat and clean!fla. jim- I don't think a shop rat would be comfortable there..especially after she who must be obeyed saw just how much stuff you have in there!"All that is required for evil to triumph is that good men do nothing"
Reply:You Fla guys can afford to have shop full because you can work outside.   BBBrrrr. it's a little frosty here.
GMT+8, 2025-12-21 08:36 , Processed in 0.085954 second(s), 18 queries .
