Finally, my fume exhauster is completed
发表于 2021-9-1 00:43:29 | 显示全部楼层 |阅读模式
Hello there,I just wanted to show my most recent project. A fume exhauster. I want to thank scott for his idea and info, and also Frank who telepathically figured out how to powered my motor. Attached Images
Reply:Another one Attached Images
Reply:Last one Attached Images
Reply:Amalgam, Het it looks great!. Glad I could help. I see you use a Speedglass, I have one also. I am very happy with it.
Reply:Amalgum you definitely had me workin on that project, and it turned out well.Your use of duct tape is impeccable.Now you need to put some of the car door edge guard on the edges of the intake funnel, before you rip open some skin,Appreciation Gains You Recognition-
Reply:Hey Franz,Great idea. I only knew that I would have to use extra care when handle it. But that Idea will take that out of my mind.
Reply:Nice......What  kinda welder do you have?...And what is under the blue tarp???Robert D
Reply:All your carts look nice and the table too. Your floor looks pretty clean, Does Mrs. Amalgam let you weld out there? Since Franzie knows how to make fumes , he knows how to get rid of them too. DavidDavid
Reply:Thank you guys for your compliments.Robert,Under the blue tarp there is a chop saw I keep it covered because right behind I have my bench grinder. So when I use the grinder I keep the chop clean and when I use the chop I cover the grinder. And my welder is a LE 175 Plus.David (echo8287)Thank you for the comments on the carts and table I will add some pictures following this reply. The floor is very clean because this is my garage and Mrs. Alamo has a complete domain of the land, even on my own territory. So as soon as I finish I clean so I do not get grounded.
Reply:Originally posted by Amalgam Thank you guys for your compliments.Robert,Under the blue tarp there is a chop saw I keep it covered because right behind I have my bench grinder. So when I use the grinder I keep the chop clean and when I use the chop I cover the grinder. And my welder is a LE 175 Plus.David (echo8287)Thank you for the comments on the carts and table I will add some pictures following this reply. The floor is very clean because this is my garage and Mrs. Alamo has a complete domain of the land, even on my own territory. So as soon as I finish I clean so I do not get grounded.
GMT+8, 2025-12-21 08:12 , Processed in 0.113480 second(s), 18 queries .
