16 ga Starting Point
发表于 2021-9-1 00:43:20 | 显示全部楼层 |阅读模式
Greetings:I am completely new to welding. I have a Miller Thunder Bolt 225 stick welder. I am at the stage where I am simply welding scraps to each other to learn how to control the puddle etc. I am blowing holes in the 16 ga pieces I have tried so far and know that I have to reduce amperage and stick diameter. Could someone provide a good starting point for me? The scrap I have is 16 ga 1" x 1" square tubing. The welder is ac/dc.Thanks, Erik
Reply:16 ga is easy. I've done it with stick for decades. The key is to use DCEN and move quickly. I use 3/32 - 6011/6010 for 16 ga. Set the machine at 60a and give it a go. You will most definitely need to get a good whip going. Watch for the puddle getting too wide...that is a clue that a burn thru is on the way.QamuIs Heg qaq law' lorvIs yInqaq puS
Reply:6013 works good too.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-21 08:11 , Processed in 0.231274 second(s), 18 queries .
