field welding
发表于 2021-9-1 00:43:19 | 显示全部楼层 |阅读模式
I have 4 fuel tanks to cut up and remove in the field. Looking at plasma vs gas welders. which is recommended? any suggestions?
Reply:What are the tanks made of?  How thick?  What kind of power do you have available?  Don't blow yourself up!!Esab TradeMaster TorchSmith AW1A Airline TorchLincoln AC/DC 225/125Millermatic 252 w/ Spoolmatic 15aThermal Arc 190 GTSSpeedGlas 9100v
Reply:I think I'd choose something that doesn't make an arc, or a lotta sparks either.   Hacksaw, anyone?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I have to say, I agree with DesertRider33.  Unless you can be absolutely certain that you aren't going to blow up the fuel tank, I wouldn't take anything involving sparks or fire around it.  Fuels in a vapor state can be much worse than in liquid forms.  Even if the tanks have been empty for years, there could still be trapped vapors that could explode if ignited...Esab TradeMaster TorchSmith AW1A Airline TorchLincoln AC/DC 225/125Millermatic 252 w/ Spoolmatic 15aThermal Arc 190 GTSSpeedGlas 9100v
Reply:Make sure you have one hand on the rip-cord.
Reply:If there ain't any gas left in them, use a D8 cat to run over them a few times and load them on a trailer to haul off to the scrap yard!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Yeah, and then some scrap yards still wont even take them!A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:If you HAVE to cut them.....Put some Dawn or other good foaming dish soap in them and spay water in them to make a HEAVY foam to the TOP of the tank that will displace the gas fumes. But, you still better have a hand on the rip cord!
Reply:Put some dawn or other good foaming dishsoap into the tank and spray water in to make a HEAVY foam to the TOP of the tank, This will displace the fume. But, keep your hand on the rip cord!:
Reply:I guess Yall can tell I'm new here!, I'll get it figgered out!
Reply:Originally Posted by Ken DennisIf there ain't any gas left in them, use a D8 cat to run over them a few times and load them on a trailer to haul off to the scrap yard!
Reply:The scrapyards that I am familiar with generally require "inspection" holes of a certain size.My name's not Jim....
Reply:Its obvious you have never been around this sort of thing.   DO NOT attempt this unless you want a Darwin award.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:A couple wraps of det cord should do the trick!Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
GMT+8, 2025-12-21 08:12 , Processed in 0.118432 second(s), 18 queries .
