boom mower retrofit
发表于 2021-9-1 00:43:18 | 显示全部楼层 |阅读模式
now when you see goose poop like this it is best to remove and see what they are trying to hide Attached Images
Reply:so grab the torch and scarf the weld and drive a chisel in Attached Images
Reply:OH THE HORROR....what some a$$O will try to hide Attached Images
Reply:cleaned up and repaired proper like Attached Images
Reply:now with that all done time to add the reinforcement back ...root pass Attached Images
Reply:and the usual 2 cover passes Attached Images
Reply:and fixed....now to do the other side Attached Images
Reply:had to shorten the belly sling by 12"....now this pic isn't good ...weldment is 2" wide ......helper didn't remove slag from it either Attached Images
Reply:we found another beak in the boom that was goose pooped ....this is after repair Attached Images
Reply:closer one ......... dots added do to 15 things to post Attached Images
Reply:now to line up hydro pump and bore holes for power shaft and get it mounted Attached Images
Reply:lined up and getting ready to mount Attached Images
Reply:now these throw away cameras ain't worth a **** but i'm to cheap to buy a digital one...root pass Attached Images
Reply:and 2 cover passes Attached Images
Reply:and other side........... Attached Images
Reply:and this is the way it sits as we speak Attached Images
Reply:another angle........ Attached Images
Reply:weld inspector/ground hog killer/hand rag ....see the 2 spot on dogs back .....grease from hands....make dog water repellant Attached Images
Reply:Boilerman,Thanks for the pics.  Neat project.Regarding the dgital camera, you only have to pay for it once.  Add up the cost of the disposables, your time and money getting them processed and the cost of wasted shots and it gets pretty expensive.Best part about the digital is you know it's a good shot as soon as you take it.  Sure sucks to shoot some pics and find out a day later they are crap.  Sure is easy to keep all you stuff organized, too.
Reply:today i patched one of the rear rims ...had a hole 3.250 x3.250 in it no pics of it ....and had to weld the power shaft cuz the dumb asses from the town it came from had hard time figurin out left handed threads so they cut it 3/4 of the way before someone straightened them out ...numberous bushings had to be welded and machined out to be rebushed ...all in all good winter project ....next project is another grain truck ...just passed one on the road for sale and got to stop and check it out ....well it is either another grain truck or a digital camera ...i vote truck
Reply:Geez BM a rattle can of RustOleum could have saved you a lot of welding time.  That's how the dealers generally do it, after all, most of the dealers know you just turn the amps down and pile weld on top, then paint.Appreciation Gains You Recognition-
Reply:Good job there Boilerman clean and neat,I can see u take pride in what u do!! Not many people do that anymore!!!!!
Reply:the boom mower was got at auction...and as you can see we took a honeing at 850 bucks for it ...and tractor was got the same ...took honeing on it to at 4700...damn thing ain't worth but 4000...but sometime you win and sometime you don't ....but it stands true ...5.00 bucks of paint worth 500 at auction....maybe we should lay off the dandilion wine before auction time ...today pissing around in the building ..took look at other rim .....yep ...going to need a patch there to ....got to call the man to tranfer the tire load before repair ...and got to get another one of them throw away film shooters to
GMT+8, 2025-12-21 08:11 , Processed in 0.106877 second(s), 18 queries .
