center speaker stand
发表于 2021-9-1 00:43:16 | 显示全部楼层 |阅读模式
Joehobart,Why don't you put velcro on the bottom of the speaker and on the top of the tv and set in on the tv?   The center speaker should be magneticaly shielded.  You may need to set the tv up on something to get it to go over the shevf leg.I took 1 inch angle Iron and made a frame for over my tv for speaker, receiver, dvd,and vcr.  I then welded a 2 inch strap be 1/8  to the front for looks and put a peice of plywood in the frame.   I am going to make a frame for the subwoofer to go over the components and tv in the corner, then make a velvet curtain to block what I don't want to see. Attached Images
Reply:Sorry, I ment for this to go to Joehobarts center speaker thread.oops
GMT+8, 2025-12-21 08:37 , Processed in 0.215362 second(s), 18 queries .
