automotive welding
发表于 2021-9-1 00:43:15 | 显示全部楼层 |阅读模式
just wanted to see whos online here that build there own roll cages,frames, exhaust, suspension peicesmachines that you are using and materialand pics would be great too
Reply:I built my own four link rear suspension for my Jeep. there are a few other guys on here that have done the same. In the world of Rockcrawling, sooner or later you will need a welder/ or weldor. For our rollcages we are using DOM tube in various diameters and we use a JD2 bender to bend it.
Reply:I bought a 74 K5 Blazer about four years ago that neede a lot of work.  I welded in some new body panels, new floors, and a roll bar ( will be a cage when I get some extra money).  I have a Licoln weld-pak 100 with the mig conversion and it does a great job.Rush
Reply:Oh yeah, and I am using a MM210.
Reply:I do my own bodywork and fab. Rollcages are left to the PRO's.A. I don't own the equipment to meet the sanctioning bodies rules
Reply:I do cages. Nothing professional. Don't charge money, can't afford the liability... I DO own a host of tools, and other than GTAW capability for CroMoly, could meet most sanctioning standards for most cage-requirements. My specialty is Jeeps.My work:The latest: http://www.printroom.com/ViewAlbum.a...lbum_id=170782http://www.printroom.com/ViewAlbum.a...lbum_id=159600http://www.printroom.com/ViewAlbum.a...album_id=89650http://www.printroom.com/ViewAlbum.a...lbum_id=136472http://www.printroom.com/ViewAlbum.a...lbum_id=143878http://www.printroom.com/ViewAlbum.a...lbum_id=107807http://www.printroom.com/ViewAlbum.a...lbum_id=110777Driving a Jeep is like drinking tequila... At some point you're gonna get the misimpression that you're bulletproof and invisible... At that point, if you're smart, all you can do is hang on and pray that it ends soon. -- Me.
Reply:I do rollcages as well.  NHRA rules state that mild steel only needs to be MIG welded, and Chromoly must be TIG welded.  I havnt had any problems with inspection so far, the welds all seem to pass.www.jmfabrications.comLincoln Precision TIG 375Lincoln Precision TIG 275Lincoln Power MIG 255Lincoln Power MIG 140CMiller Dynasty 350 (x2)TD Cutmaster 80
Reply:Working on fabbing up some new suspension bits to fit some volvo portals under my Land Cruiser.  Modifying a bunch of junk and making some junk.  All so I can wheel my junk.
Reply:I have a 71 Bronco that I have been wanting to make a rolla cage for so I can take off the top in the summer. What size and type of tubing is usually used for these?shane las vegas, nv
Reply:radius arm bracketshttp://www.superford.org/getfile.php...e=DSC00693.JPG http://www.superford.org/getfile.php...e=DSC00242.JPG http://www.superford.org/getfile.php...e=DSC00310.JPG track arm bracket & brace to crossmemberhttp://www.superford.org/getfile.php...e=DSC00280.JPG http://www.superford.org/getfile.php...e=DSC00281.JPG http://www.superford.org/getfile.php...e=DSC00286.JPG a buddy's tube workhttp://www.superford.org/getfile.php...e=DSC00703.JPG
Reply:Bluesman,I noticed a pic of your drill press and the coping fixture. Do you have a better pic of that? I'm looking for a decent coper.oldebrush
Reply:Oldebrush, it's a JD2, TN-100.http://www.jd2.comHere's a better pic of my setup:http://www.printroom.com/ViewAlbumPh...74&image_id=34Driving a Jeep is like drinking tequila... At some point you're gonna get the misimpression that you're bulletproof and invisible... At that point, if you're smart, all you can do is hang on and pray that it ends soon. -- Me.
Reply:I take it that someone will mention that its not ok to be weldin roll cages with a Weld Pak 100?www.urkafarms.com
Reply:Originally posted by Sberry I take it that someone will mention that its not ok to be weldin roll cages with a Weld Pak 100?
GMT+8, 2025-12-21 08:11 , Processed in 0.088029 second(s), 18 queries .
