hello, I'm new to welding
发表于 2021-9-1 00:43:10 | 显示全部楼层 |阅读模式
This is a very basic question but I would appreciate your knowledge. What is an all- position electrode?
Reply:Welcome to the forum!  An all position rod/electrode is one that can be used in flat, horizontal, verticle, overhead, etc.  It differs from other rods that may be primarily designed for use in just one position such as flat or overhead etc.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:That helps a lot
Reply:7024 is a flat/horizontal only rod.  That's the only restricted position rod I can think of off hand.  Most of the rest of them are all-position.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:You can identify the position limitation (or lack thereof) by the number of the rod.  The first two digits refer to the tensile strength of the steel in the rod -- usually 60 or 70, which means 60,000 or 70,000 psi tensile strength.  The third digit identifies the welding position(s) the rod/flux combo are designed for -- 1 is for all positions, 2 is for both flat and horizontal (but not vertical), 3 is for flat only.The fourth digit identifies the flux coating, which also plays a role in its suitability for AC or DC current, and whether the polarity used should be electrode positive or electrode negative.      * EXX10 DC+ (DC reverse or DCRP) electrode positive.    * EXX11 AC or DC- (DC straight or DCSP) electrode negative.    * EXX12 AC or DC-    * EXX13 AC, DC- or DC+    * EXX14 AC, DC- or DC+    * EXX15 DC+    * EXX16 AC or DC+    * EXX18 AC, DC- or DC+    * EXX20 AC ,DC- or DC+    * EXX24 AC, DC- or DC+    * EXX27 AC, DC- or DC+    * EXX28 AC or DC+(The E at the beginning is for 'electrode,' which is what a stick is.)Jack OlsenMy garage website
Reply:Good job Jack, you pretty much covered it all!A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:I'm gonna copy part of Jack's explanation of those rods and the numbers meanings,been wondering that for awhile,thanks Jack!Drink a Guinness Draught....Millermatic 140Do you still rememberDecember's foggy freeze --when the ice thatclings on to your beard isscreaming agony.
GMT+8, 2025-12-21 08:13 , Processed in 0.092285 second(s), 18 queries .
