查看: 13|回复: 0
Quess what it is?
发表于 2021-9-1 00:43:09 | 显示全部楼层 |阅读模式
This is a welder my old company was going to toss.  So I asked if I would have it.  Well it's hard to tell since the face plate is facing the cab.  Maybe I will jump in the truck and open the back window for a face plate shot. Attached Images
Reply:I can guess what it is..... It's BIG!Sure has the truck sitting down in the back. Congrats on getting the machine and cylinder. Not a bad deal at all........ pgDynasty 200 DX_set up to run on 3 phaseCoolmate 3MM 251 w/ Spoolmatic 30AHTP 625 Micro Cut Plasma CutterVictor O/A RigBridgeport Mill_3 phase10 inch South Bend Lathe_3 phaseQuincy 325 2 Stg. Air Compressor_3 phase
Reply:I bet it's a old Hobart welder :PDrink a Guinness Draught....Millermatic 140Do you still rememberDecember's foggy freeze --when the ice thatclings on to your beard isscreaming agony.
Reply:Its the color of a hobart but could be an ice cream cooler from the size,looks like three phase power with that wanky plug.Nice score if you gots the juice.FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:It's a Hobart RC-750, Dual wire feed.  And that bad boy weights over 1600 pounds.  We weighed it before putting it on my truck.  Have the power, just need to make the space.  Plan on running 1 Solid wire and 1 Flux core.
Reply:It looks like a Nissan frontier that's HATEING life.   oh and some sort of Hobart welder.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Well the Nissan is feeling better now.  Here are some shot's of the front panel. Attached Images
Reply:Gotta love companies that give stuff away just to get rid of it.  And you have the power to run it too!!Nice score.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Have you gotten it up and running and welding with it yet? How about a little video of it working?Drink a Guinness Draught....Millermatic 140Do you still rememberDecember's foggy freeze --when the ice thatclings on to your beard isscreaming agony.
Reply:Not up and running yet.  That will be in a couple of weeks.  I have the power at the shop, but have to re-wire it to that side.  Also have to make room.  For some reason it does not fit in the space of my other welders......
Reply:I'm thinking that reason is that it's an ENORMOUS CHUNK of FLOOR SPACE to fit next to most regular sized machines!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Tha's nice... tha's real nice. TD, I don't know. Can 750 -count ‘em- amps, and twin feed, be had in a much $maller footprint?Partagas, what are her measurements? Maybe  48" - 36" - 40"  or so?Good LuckLast edited by denrep; 09-19-2009 at 07:20 AM.
Reply:power company gonna love youcongrats on the score
Reply:Originally Posted by denrepTha's nice... tha's real nice. TD, I don't know. Can 750 -count ‘em- amps, and twin feed, be had in a much $maller footprint? Your gonna need a bigger shoehorn!Partagas, what are her measurements? Maybe  48" - 36" - 40"  or so? <-----?? Good Luck
Reply:I will have to take measurements next week.  Not going to be near the shop for awhile.It can run on 220 or 440.  220 can only use one wire feed
GMT+8, 2025-12-21 08:38 , Processed in 0.094127 second(s), 18 queries .
