stainless steel a/c
发表于 2021-9-1 00:43:08 | 显示全部楼层 |阅读模式
I have a need to weld 1/4" thick 316 S.S.. The SS box contains magnets, magnets affect D.C.   I would like to use the syncro 350 on AC. any tips, ideas, tung recommendations?Thanks, Tim.Tim Beeker.
Reply:I don't know about the welding, but A/C may weaken the magnets . . . . heat wont do them any good either . . .-- fredLincoln 180C MIG
Reply:Thank you for the response.They are rare earth,Heat will not each them, hopefully the ac will not affect them much either.Tim Beeker.
Reply:GTAW AC requires zirconiated tungsten. I think ceriated would also work. Would not advise GTAW AC on SS though, perhaps consider SMAW AC. Give GTAW DC a go on the 316 in the vicinity of the magnets, it may work.
Reply:Thoriated works fine on AC too.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Hey DesertThat may work at the lower end of the current range, however for arc stabilty, current carrying ability and lower risk of weld contamination, zirconiated is a better choice for AC. Thoriated will struggle to cope with the AC positive half cycle.Cheers
Reply:Ok, Thanks guys. I'll give it a try.Tim Beeker.
Reply:Originally Posted by chrispc66That may work at the lower end of the current range, however for arc stabilty, current carrying ability and lower risk of weld contamination, zirconiated is a better choice for AC. Thoriated will struggle to cope with the AC positive half cycle.
Reply:Originally Posted by chrispc66Hey DesertThat may work at the lower end of the current range, however for arc stabilty, current carrying ability and lower risk of weld contamination, zirconiated is a better choice for AC. Thoriated will struggle to cope with the AC positive half cycle.Cheers
GMT+8, 2025-12-21 08:37 , Processed in 0.375761 second(s), 18 queries .
