Help with my set up
发表于 2021-9-1 00:42:59 | 显示全部楼层 |阅读模式
I have recently begun trying to weld and am having issues finding suggested settings for my welder. I have aMiller XMT 300 CCconnected to a suitcase Miller 12VS MIG 400 am profax torch. I have found the settings used in the manuals on how to control wire speed but have no idea on how to set the heat or arc strength. On the sheet for the suitcase, in the manual, it describes knowing arc voltage and wire speed? Are these listed somewhere for different thickness metals that I have missed.I am sure this is a stupid question but I would appreciate any help anyone could give.
Reply:Welding parameters will differ dependent on the consumablesused, eg: solid wire, cored, gassless, dual shield etc, the welding position, base material type / section and thickness, Lincoln provides excellent welding parameter guidelines, the internet or your local bookshop will help.Good luck
Reply:Right - Well I am using .035 flux core wire. The material i am welding on is some 16 guage 2" round stock. I have to weld it to a 1/4" think piece as well and to itself.
Reply:Try herehttp://www.millerwelds.com/resources...calculator.phpEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:That was the ticket I was able to tune it in from there. THenks alot. I will now not be albe to sleep thinking about getting this project done. Lovein it.
Reply:Your wire manufacturer will also most likely have setting parameters listed on their website for that particular wire.   Lincoln, Hobart and ESAB all provide that info.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by weldingnewbieI have recently begun trying to weld and am having issues finding suggested settings for my welder. I am sure this is a stupid question but I would appreciate any help anyone could give.
GMT+8, 2025-12-21 08:38 , Processed in 0.103807 second(s), 18 queries .
