2nd project..work in progress
发表于 2021-9-1 00:42:52 | 显示全部楼层 |阅读模式
The metal work is done, but need to finish the top... Attached Images
Reply:just another angle..my photography skills suck.... Attached Images
Reply:Very nice, John.  What kind of wood are you using for the top?
Reply:Not sure what it is..its fairly light in weight and was taken from an old table top I had laying around. Not thrilled with it but dont have another option at this point. I need 14 inches wide and not finding anything that wide locally. Checking at a saw mill this weekend for options...Im not much of a wood worker, so I hesitate to try to put two pieces together...Now, if I could only weld them together and grind the seam......
Reply:I like the Mission look.  I bet the top will also look great once you get it refinished.
Reply:Ive got a matching table for the tv, also the mission look, laid out and ready to go as soon as I get through this tabletop issue
Reply:Very nice.   I like the clean straight lines.
GMT+8, 2025-12-21 08:09 , Processed in 0.070009 second(s), 18 queries .
