toys
发表于 2021-9-1 00:42:43 | 显示全部楼层 |阅读模式
just some pictures of my toys and projects Attached Images
Reply:just hope this is the 4500 Attached Images
Reply:these are the frame members for the roof. Attached Images
Reply:same from another angle Attached Images
Reply:hmmm, now you gotta clue me in on the frame's purposeStangnetShop Full Of Stuff. Joey
Reply:You need to plant some grape vines on that arbor to soften the edges up a little.  Or is that an exoskeleton for the tornado magnet?
Reply:i am going to put a roof over the trailer
Reply:OK, so you don't need to consider snow load, BUT, I think you need to put some additional bracing in the trusses.  There neds to be a triangular factor for maximum strength.If wind is a consideration, adding a diagonal from post to truss would provide a lot of strength enhancement.Appreciation Gains You Recognition-
Reply:is that a home or a office
Reply:rookieit is a deer camp only used when we need to get away.franzi will brace it from truss to truss when get the time thanks for the post all                        ken
Reply:Originally posted by dulknife i am going to put a roof over the trailer be cheaper to fix the trailer roof
Reply:Originally posted by boilerman Originally posted by dulknife i am going to put a roof over the trailer be cheaper to fix the trailer roof
Reply:I have an almost identical  roof over my Texas mobile.  Its wider than the trailer, covering a full lenght 8 foot enclosed porch along one side, and a paved patio on the other side as well.  I am on the side of a hill, almost at the top.  The roof has been on probably15 years, and now has a definite 4 to 6 inch "bend" away from the prevailing winds in all the uprights that reflects years of wind exposure.  I wish they had used even 1/4 larger uprights, and preferably double-sized them.  Now it will be easy and cheap for you to re-enforce those uprights, and triangulate them as well.  In my case, we haven't figured out how to staighten the uprights out.  Right now, I'm afraid the roof loads will cause them to bend more and more, and may lead to a collapse.  I thought of super-clamping all the verticals to pull them back into plumb, then welding on sister pieces of angle or channel iron.  Lots of work and cost now, but sure would have been easier to put a little more steel in it back when.  My 2 centavos worth, my friend.At the Lake
Reply:thanks for the post i will brace it as soon as i can come up with the pipe. what size pipe did you use. i have built a lot of catch pens with roofs. have had on problems. is really windy where you are. i took some pictures today i will post them.  ken
GMT+8, 2025-12-21 09:08 , Processed in 0.068052 second(s), 18 queries .
