help unkown welder
发表于 2021-9-1 00:42:36 | 显示全部楼层 |阅读模式
just got a as far as i can figure a starline 180 model 10-404 ac welder i got it in trade i knwo nothing about this welder i looking for info on it maybe a lionk to the manual or company its a stick welder
Reply:hear are some images some one please help i need the manual or link to or just some info onthis machine
Reply:It looks like there is an address on the bottom of the data plate.Have you tried to Google the company?Rex
Reply:If you look at the bottom of the tag, it identifies the manufacturer as Marquette.  A fine old welder company.  Probably not as popular as Forney but in the same range of quality.  It is now owned by Lincoln.Last edited by lugweld; 07-26-2009 at 08:56 AM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I don't think Marquette is around anymore(got bought out and then the company that bought'em out went under?) I been looking for any links at all for a manual for this welder or even any old posts,seems like a dead end,I hope maybe someone else will have better luck,at least you have that recommended guide on that plate to help you when you wanna do some welding.
Reply:well i apreciate any help i can get it works really well i did some practice with some 3/32 7018 and it never had an issue so if any one can help please do id love to knwo more about it
Reply:If you find that manual there not going to be that much info in it. All there is to one of those wel;ders is a transformer and a switch. I don't even think those had a fan, may it does I can't remember. That also means that harldy anything ever goes wrong. If the switch ever goes bad I thing a little digging would turn up something newer that would work, or you could get fancy and install a toggle switch and a contactor.Tough as nails and damn near as smart
Reply:I repeat, LINCOLN bought out Marquette and Century.  They are still afloat.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldI repeat, LINCOLN bought out Marquette and Century.  They are still afloat.
Reply:Originally Posted by tresiIf you find that manual there not going to be that much info in it. All there is to one of those wel;ders is a transformer and a switch. I don't even think those had a fan, may it does I can't remember. That also means that harldy anything ever goes wrong. If the switch ever goes bad I thing a little digging would turn up something newer that would work, or you could get fancy and install a toggle switch and a contactor.
Reply:Originally Posted by tresiMan, my spelling is bad. That's what I get for getting up before the crack of noon on a Sunday.
Reply:hey guys thanks for all your help i will call lincoln tommorow and see whats up also yes it does have a fan in it will this welder work with just general steel wleding also are 7018 IA better then 6010
Reply:Originally Posted by cjfalkenburyhey guys thanks for all your help i will call lincoln tommorow and see whats up also yes it does have a fan in it will this welder work with just general steel wleding also are 7018 IA better then 6010
Reply:That is a tapped transformer that makes AC in 5 amp increments, choose any welding rod ending in a digit other than 0 and 5 which are for DC positive, and it will run just fine. Good for lots of different rods like E6011, E7014, E7018AC or E7024 in the flat position, I bet it runs E6013 like a dream! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Hey I have a starline powerpack model 14-400.  I haven't found a single thing online for any kind of information on this unit either!  I do know that it is something that I found on a load of junk coming in to the junkyard close here, I asked the old guy if I could have it, if for nothing else it was cute and thought I could make a clock out of it for the shop. I come to find out that it is one of the handiest little welding machines I have ever seen!!! I know it is small, but wow does it pack a punch for it's size! If your's is anything like this one, you will be happy with it for small jobs where a big guy is just too much! Mine looks like a mini version of the older lincolns like my 250, but with 3 ranges - low medium and high, and the work lead port.  I wish I could find more info on it, but I am very happy with it so far!
GMT+8, 2025-12-21 08:37 , Processed in 0.070624 second(s), 18 queries .
