Fab hitch for riding lawnmower?
发表于 2021-9-1 00:42:34 | 显示全部楼层 |阅读模式
I have a 17.5hp Scotts/JD mower, front engine. It has the flimsy thin metal lip with a hole punched in it. This piece has bent after towing my aerator and trying to pull a trailer.I want to fab something up for the back. Anyone have any pictures or ideas? I want something sturdy and a little higher from the ground. I need some ideas guys.Thanks
Reply:what about tracing the existing stamped out one with heavier stock and bolting it on ?  or you could just go nuts and go the OVERKILLED WAY ?
Reply:my mower had the same kind of deal. I fabbed up a piece that bolted to the frame that had some beef to it, problem solved. let me see if I can find the pic, if not I'll take another one.edit: here's the pic: at the time all I had was a short piece of stock that was thick enough so I made do with it. I need the hole offset because of how big a trailer I was pulling with my little mower. I still haven't cut that off and replaced it yet with one that has a hole in the center and offset to the side.Last edited by morpheus; 05-05-2004 at 05:39 PM.
Reply:THANK YOU!! Exactly what I was looking for!!
GMT+8, 2025-12-21 09:08 , Processed in 0.093195 second(s), 18 queries .
