looking 4 leverage multiplier 4 HF bender
发表于 2021-9-1 00:42:32 | 显示全部楼层 |阅读模式
Too anyone out there,I,m looking for plans, info, pics, or web sites on constructing a leverage multiplier kit for the Harbor Freight compact bender, bench or floor stand type. Any info on this subject is appreciated.Thanks,Mariner41
Reply:Best thing I can think of is look at the Shop Outfitters site and use that for your model.  Never have seen one for the HF bender.
Reply:I've found some info on the leverage multiplier on the U.S. Patent Office under patent # 5626045, http://www.uspto.gov/patft/index.htm It gives good detailed drawings and theory of operation of the device. The only thing it does not give is exact specs. I think with a little studing, someone could adapt the assembly to the Harbor Freight bender. The only thing about this site is that you need to have a Tiff viewer that they specify in order to view and save the drawings. The viewer is free to download and easy to install. I hope this helps. Also I hope you can post your pics if you try this project.mariner41
GMT+8, 2025-12-21 09:24 , Processed in 0.082942 second(s), 18 queries .
