project stuff link in signature
发表于 2021-9-1 00:42:31 | 显示全部楼层 |阅读模式
Just seeing if the link to some project stuff works.Edit:  Insert this into you signature line on your user control panelProject PicsLast edited by vipermanz; 05-09-2004 at 11:47 PM.www.urkafarms.com
Reply:I dont know anything about puters cept how to flirt with girls so I guess it isnt a link, copy and paste to get to the pics.www.urkafarms.com
Reply:maybe like this? I 've added a link to my web page at the end of my sig block.Last edited by Paychk; 05-08-2004 at 10:29 PM.
Reply:URL HyperlinkingIf vB Code is enabled in a forum, you can simply type in the full address of the page you are linking to, and the hyperlink will be created automatically. Here are some example links:http://www.vbulletin.com/forum/ www.vbulletin.com Notice that if the address begins with www. you do not need to add the http:// part of the address. If the address does not begin with www. you will need to add the http:// section. You may also use https:// and ftp:// links, and these will be converted into links.If you want to include the vB Code, you may simply surround the address with [url] tags as shown below. (The vB Code tags are shown in red).www.vbulletin.com/forum/You can also include true hyperlinks using the [url] tag. Just use the following format:Click here to visit the vBulletin forumsThis will produce a hyperlink like this: Click here to visit the vBulletin forums.Note that once again, you need not include the http:// if the address begins www.HTH
GMT+8, 2025-12-21 09:16 , Processed in 0.088317 second(s), 18 queries .
