Copper to stainless Tid welds
发表于 2021-9-1 00:42:28 | 显示全部楼层 |阅读模式
Is it possible to weld copper pipe fittings to stainless? I have a client who is currently using silver solder for this joint. A TIG welded joint would be much faster and cheaper. Thanks!
Reply:This came up on a different forum a while ago. Getting enough heat into the copper without cooking the stainless may be difficult without preheating the copper. A nickel (erNi-1) or CuNi (erCuNi-7) filler can be used. Can also join the two alloys with aluminium bronze
Reply:Originally Posted by metalhoseguyIs it possible to weld copper pipe fittings to stainless? I have a client who is currently using silver solder for this joint. A TIG welded joint would be much faster and cheaper. Thanks!
GMT+8, 2025-12-21 08:37 , Processed in 0.070851 second(s), 18 queries .
