i need help
发表于 2021-9-1 00:42:25 | 显示全部楼层 |阅读模式
i bought a miller xmt 304 and it has tig on it but i dont know how to hook up the argon to it, in the tig gun at back of cable where it connects to the positive on the welder there is a port that it may go in to but im not shure
Reply:You'll be using scratch start with the XMT. With that being said, hopefully your torch has an on/off gas valve on it.Follow your torch back and there should be a "Y" joint where the gas hose connects from the argon bottle. Did you get a regulator/flow meter with the unit? You'll want to use DC- (straight) polarity with tig.The XMT 304 is a VERY good scratch start tig machine.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:correctionthe XMT should have a lift arc start tig.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:nn240, the Miller XMT-304 CC/CV (unlike the XMT-350 CC/CV) has no provision for an internal hookup for argon.  As snoproe said, you're stuck with using a tig torch with an integrated gas knob or switch on the handle.  That's a lot easier to deal with than running back to the flowmeter before and after every weld to turn it on and off, not to mention the argon gone to waste.ScottMiller XMT 350 CC/CV w/gas solenoid opt.Miller S-22A wirefeederBernard 400A "Q" gunMiller Spoolmatic 30A / WC-24C-K 200A torch/gas lensWeldcraft WC-18 watercooled torchHypertherm Powermax 30Victor O/A
Reply:Do yourself a big favor, go to Miller's site and downloadthe manual on this machine.Blackbird
Reply:It is easiest to connect the torch if you have a torch with seperate power and gas connectors.  You need a Dinse connector for the power cable and then connect the torch's gas hose to the gas hose comming off the regulator.  I use a quick-disconnect from Western to connect the gas hoses.   My torch has the gas valve in the torch handle.   I prefer the scratch start with foot pedal than the lift start on my XMT.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-21 09:08 , Processed in 0.093764 second(s), 18 queries .
