Tire Rack installed
发表于 2021-9-1 00:42:22 | 显示全部楼层 |阅读模式
Here are the pics. of the tire rack I built not long ago for a racecar shop.  Also a couple pictures of a Furnance frame I built that fits above the door. Attached Images
Reply:Another angle of frame Attached Images
Reply:Tire rack on the wall Attached Images
Reply:Another angle of the tire rack Attached Images
Reply:The test!  I told my father-in-law to test it out, held up great to the assault, so did the tire rack. Attached Images
Reply:Looks good Tom another fine job,liked the furnace frame to
Reply:Nice looking job(s) Tom.
Reply:Don't know what I would do with it, but that makes me just want a tire rack.
Reply:Look out beloooooow.Just joking, it looks really nice.
Reply:been a long time since I've seen a IBM tab card cabinet... they make good parts cabinets with removable drawers  ...if you find the kind with a solid bottom    nice job on the tire rack... what did you use to mount to the block wall  john
Reply:Tire Rack has 18 through bolts (all thread) with matching plates on the outside of wall.
Reply:Originally posted by jniolon been a long time since I've seen a IBM tab card cabinet... they make good parts cabinets with removable drawers  ...if you find the kind with a solid bottom    nice job on the tire rack... what did you use to mount to the block wall  john
GMT+8, 2025-12-21 08:18 , Processed in 0.094818 second(s), 18 queries .
