Oval Aluminum Pipe
发表于 2021-9-1 00:42:15 | 显示全部楼层 |阅读模式
Hello all, its been a while since I have last frequented here. I have a new project coming up that requires the use of oval pipe for some torsional bracing. I am hoping to use Aluminum as my base material but steel will do as well.I am not sure what the correct term is for the shape/form of the tubing I need but this link provides a good visual reference.http://www.tacomarine.com/cat--Oval-...pipe_oval.htmlDoes anyone know of a good online supplier of this type of tubing/pipe?I can't seem to find any metal supplier in my area that carries it and I am now resorting to an online supplier. Any info on this would be much appreciated.
Reply:Try Morse industries. We get boat tower tubing and fittings from them. Not cheap, but they have it!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
GMT+8, 2025-12-21 08:26 , Processed in 0.131035 second(s), 18 queries .
