other sights
发表于 2021-9-1 00:42:08 | 显示全部楼层 |阅读模式
hi to all  i just found this sight, and i have been looking as some projects. i like the "lift up table" and am going to try to construct one, it will be great for taking blades off lawn mowers; ect.are there any other sight, with this kind of information on it? any sight appreciated. i learned how to wire weld in the 70's at an auto plant. have take clases on stick welding. i have had a lincoln 110 and a  miller 220 sitck welder.my current welder is a readywelder.  www.readywelder.comit runs from two or three deep cycle battries. for what it do it perfect. in my opnion it has more power that the lincoln, or miller small 110 volt welders. (it has a 100% duty cycle) untill the battries run low.thanks to all for the post that i have readgean
Reply:look in the links forum at the bottom of the main pageStangnetShop Full Of Stuff. Joey
Reply:gean,Which auto plant did you work at? I was at GM in Janesville during that same time period.
Reply:I worked at AMC/Chrysler untill plant closing in 1988, in Kenosha, Wisconsin.
GMT+8, 2025-12-21 08:09 , Processed in 0.087813 second(s), 18 queries .
