Pressure Domes and Cylinders
发表于 2021-9-1 00:42:07 | 显示全部楼层 |阅读模式
Apologies for this total newbie asking simple questions here, but I'm just trying to understand the methods properly.We have a project to build a wide diameter (10ft) steel cylinder which will contain two separate pressure vessels, like so:.______________(______)_(______)One critical requirement is that the outside of the cylinder be a constant 10ft diameter throughout its length.   This structure is going to have significant loads put through it end-to-end (it will actually be mounted vertically with a lot of weight on top), so the loadpaths down the cylinder walls need to be carefully retained -- most especially through the unpressurized area between the two tanks!From what I already understand, the most efficient way to attach a pressure dome to a cylinder is to simply weld it on as an endcap, using a dome which is the same diameter as the cylinder and a double-vee preparation joint on both elements.But then how would you go about attaching the 'extension' part of the cylinder between the two tanks in order to preserve that 'flat' cylinder wall?What's the best approach in this situation?Could a dome be safely welded inside the cylinder itself?   If so, can anyone suggest the correct type of joint which would be required?Do we need to consider getting a custom-made "Y" ring manufactured?Many thanks for any advice or suggestions.Jay.
Reply:Jay,Try cross posting this to the ASME pressure vessel forum at www.eng-tips.com.  You stand a better chance of getting the kind of design/engineering information you're looking for there, than you do here.  This forum tends more towards the practical, hands-on aspects of welding, and not the technical design aspects.That said, I'm not really sure I understand the problem from your written description and ASCII character sketch.  Can you post a real drawing of the tank?Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Originally Posted by jsheridanApologies for this total newbie asking simple questions here, but I'm just trying to understand the methods properly.We have a project to build a wide diameter (10ft) steel cylinder which will contain two separate pressure vessels, like so:.______________(______)_(______)One critical requirement is that the outside of the cylinder be a constant 10ft diameter throughout its length.   This structure is going to have significant loads put through it end-to-end (it will actually be mounted vertically with a lot of weight on top), so the loadpaths down the cylinder walls need to be carefully retained -- most especially through the unpressurized area between the two tanks!From what I already understand, the most efficient way to attach a pressure dome to a cylinder is to simply weld it on as an endcap, using a dome which is the same diameter as the cylinder and a double-vee preparation joint on both elements.But then how would you go about attaching the 'extension' part of the cylinder between the two tanks in order to preserve that 'flat' cylinder wall?What's the best approach in this situation?Could a dome be safely welded inside the cylinder itself?   If so, can anyone suggest the correct type of joint which would be required?Do we need to consider getting a custom-made "Y" ring manufactured?Many thanks for any advice or suggestions.Jay.
Reply:Black I had that same thought. Any competent structural engineer should be able to design this, for a price.
Reply:I'm not a welder, nor a mechanical engineer. I never claimed to be one. I'm actually COO of a company who did $1.6 billion of shipbuilding work last year.All I wanted was to understand a little more about the process involved in a new project which appeared to be an "interesting challenge" when it crossed my desk. I wanted to learn something new for myself which I did not understand before.   You see, its actually surprisingly difficult for someone in my position to go down to the yard and just ask the guy running the arc welder -- if I go do that, the guy usually has a heart attack and starts wondering when his pink slip is coming, so I try not to worry them that way unless I have no alternatives -- hence the reason I'm asking on a forum.Unfortunately, responses like dave powelson's and fat bastard's are not in the least bit constructive nor useful -- in fact they are downright unpleasant and confrontational -- an extremely poor way to welcome any new members to this site.Thankfully, I have already received answers to my questions on a different discussion forum where hostility was not the automatic reaction to such questions. On that forum, their membership bothered to take a little time to actually try to answer my question and their answers have helped me to understand the process a little better, even though I am not directly involved.I doubt it will really matter, but given the tone of the responses here I have no intention of ever returning to this forum after posting this message.The forum webmaster should also note that this attitude from two of your members has reflected very badly on this site and I have decided to advertise on the other forum instead of this one -- specifically because of this.I shall not return again, so don't bother posting any replies. They will go unread.So long and thanks for all the, well, nothing...JS.Last edited by jsheridan; 10-16-2009 at 03:14 AM.
Reply:I'd be willing to bet that if you had stated that you are just a suit trying to understand what the yard guys are doing up front, you would have gotten nicer replies.My name's not Jim....
Reply:I shall not return again, so don't bother posting any replies. They will go unread.
Reply:Originally Posted by jsheridanI'm not a welder, nor a mechanical engineer. I never claimed to be one. I'm actually COO of a company who did $1.6 billion of shipbuilding work last year.All I wanted was to understand a little more about the process involved in a new project which appeared to be an "interesting challenge" when it crossed my desk. I wanted to learn something new for myself which I did not understand before.   You see, its actually surprisingly difficult for someone in my position to go down to the yard and just ask the guy running the arc welder -- if I go do that, the guy usually has a heart attack and starts wondering when his pink slip is coming, so I try not to worry them that way unless I have no alternatives -- hence the reason I'm asking on a forum.Unfortunately, responses like dave powelson's and fat bastard's are not in the least bit constructive nor useful -- in fact they are downright unpleasant and confrontational -- an extremely poor way to welcome any new members to this site.Thankfully, I have already received answers to my questions on a different discussion forum where hostility was not the automatic reaction to such questions. On that forum, their membership bothered to take a little time to actually try to answer my question and their answers have helped me to understand the process a little better, even though I am not directly involved.I doubt it will really matter, but given the tone of the responses here I have no intention of ever returning to this forum after posting this message.The forum webmaster should also note that this attitude from two of your members has reflected very badly on this site and I have decided to advertise on the other forum instead of this one -- specifically because of this.I shall not return again, so don't bother posting any replies. They will go unread.So long and thanks for all the, well, nothing...JS.
Reply:Forum Baiting by JSheridanJS has left us in a huff--after displaying his  style of 'management', as the Chief Operating Officer of an 1.6 bn shipbuilder.Rather than discuss this project-(an externally loaded, 2 tank, custom pressure vessel assembly) with the appropriate design engineering and manufacturing staff involved, he sought second opinions from web forums--presumably to counter the plans of the ultimately responsible parties that will be tasked with this work.       IOW--he doesn't like the answers and costs his own technical people are giving him;and feels that he could get the 'right answers', if he could discuss this with weldors on the shop floor----but that's 'surprisingly difficult' to do, since he heads up a company that enforces the stratification of management......."it's us---against them".He expected finite, accurate answers to complex design problems while still not recognizing that this is outside the scope of reality--custom pressure vessel design by internet forum committees........after all, it's just 2 tanks, joined with a metal ring....what's so hard to do about that? Originally Posted by jsheridanI'm not a welder, nor a mechanical engineer. I never claimed to be one. I'm actually COO of a company who did $1.6 billion of shipbuilding work last year.All I wanted was to understand a little more about the process involved in a new project which appeared to be an "interesting challenge" when it crossed my desk. I wanted to learn something new for myself which I did not understand before.   You see, its actually surprisingly difficult for someone in my position to go down to the yard and just ask the guy running the arc welder -- if I go do that, the guy usually has a heart attack and starts wondering when his pink slip is coming, so I try not to worry them that way unless I have no alternatives -- hence the reason I'm asking on a forum.Unfortunately, responses like dave powelson's and fat bastard's are not in the least bit constructive nor useful -- in fact they are downright unpleasant and confrontational -- an extremely poor way to welcome any new members to this site.Thankfully, I have already received answers to my questions on a different discussion forum where hostility was not the automatic reaction to such questions. On that forum, their membership bothered to take a little time to actually try to answer my question and their answers have helped me to understand the process a little better, even though I am not directly involved.I doubt it will really matter, but given the tone of the responses here I have no intention of ever returning to this forum after posting this message.The forum webmaster should also note that this attitude from two of your members has reflected very badly on this site and I have decided to advertise on the other forum instead of this one -- specifically because of this.I shall not return again, so don't bother posting any replies. They will go unread.So long and thanks for all the, well, nothing...JS.
GMT+8, 2025-12-21 01:23 , Processed in 0.193221 second(s), 19 queries .
