Bender Stand
发表于 2021-9-1 00:42:03 | 显示全部楼层 |阅读模式
Heres my my bender stand.. 4in x 1/2in wall Dom round tube, and 3/8 mounting plates..still needs so finishing touches, like grinding the edges, and paint... Attached Images
Reply:All stick welded useing 6011 for a root pass and 7018 to cover.. Attached Images
Reply:will be mounted to the floor useing 1/2 x 7/8 in double exspansion concreet anchors.... Attached Images
Reply:if your talking about a stand for a "harbor freight" style bender ??here's another option that doesn't take up any floor space..johnhttp://www.clubfte.com/users/jniolon...ypeBender.html
Reply:Stand is for a Model 3 tube bender from M-Tech....
Reply:Great job, looks like mine. After using the bender I want to add a tool tray to the stand. Someting to hold soapstone, tape measure, marker, and definatly a jar of motor oil and brush.I do understand that's why I drive a Toyota!!
Reply:Had though about that but have disided to build a cart to hold the die's, lube, and tools... I want to keep the stand lite, has to be portable enough to mount in 3 diffrent garages....
Reply:Looks great!  I'm building a hydro setup based on the model 3 like Jay K's How is the model 3 working out for you?
GMT+8, 2025-12-21 08:38 , Processed in 0.098515 second(s), 18 queries .
