Beginner fixin' car!
发表于 2021-9-1 00:42:03 | 显示全部楼层 |阅读模式
Sorry folks.  Cannot link to the pictures as planned..Once I figure it out, I 'll give you the story and the photos.Last edited by Mic; 09-03-2004 at 02:50 AM.
Reply:So, here is the story.  I take my 95 Mustang GT up on a curb and back down onto its underside.  My car suddenly becomes much louder.  I find cracked weld above cat and now I get to weld it.Catch: I was jus given this welder a few weeks ago and am not that good a welder yet.  Check out the pics and see for yourself.I think it will hold though.  This welding stuff is pretty cool!!!Okay, here is a picture of the cracked weld. Attached ImagesLast edited by Mic; 09-03-2004 at 03:08 AM.
Reply:Pic 1 of the repair job. Attached Images
Reply:Pic 2 of repair job. Attached Images
Reply:Pic 3 of repair job. Attached Images
Reply:Pic 4 of repair job. Attached Images
Reply:And finally, my test setup to verify that I didn't have any pinhole leaks in my weld job.  I put the vacuum hose on the blower port, pressurized the tailpipe with this, capped off other tailpipe and both ports that go to the headers, and checked for air leaking out.Sounds weird, but that is how I found the leak.  If you noticed, the leak was on the top of the cat and this was not easily visible from below the car, where I expected the problem. Attached Images
Reply:cool, looks good to me, i was under a 97 pony today changing the oilStangnetShop Full Of Stuff. Joey
GMT+8, 2025-12-20 21:58 , Processed in 0.096900 second(s), 18 queries .
