Im gonna try making this..
发表于 2021-9-1 00:42:01 | 显示全部楼层 |阅读模式
im gonna try making this soon, anyone got any advice, or how hard it should be? Attached Images
Reply:Where are you going to mount the 1100CC motorcycle engine though? PsychoKart
Reply:lol.. maybe i could extend it more, because i got a cr250 engine ( nothing compared to yours lol)
Reply:Actually, I'm making a junoir rail-job myself at the moment. I've got a honda rebel 450 engine on a go-cart frame that has been extended to adult size. If you have the right tools and parts then it's not that bad. I extended the frame, braced the frame, and cut up the motorcycle and put on the engine within one Sunday, but I came to a halt and had to form a search party to find a chain rear-end. I setup the foot shifter to a hand shifter and ran the gas and clutch cables to foot pedals. Other than the rear-end, it is going pretty well.
Reply:The big problem will be bending the square tube unless you have a shop that can do it.Hank
GMT+8, 2025-12-21 12:47 , Processed in 0.040306 second(s), 17 queries .
