Does brass react with aluminium?
发表于 2021-9-1 00:41:57 | 显示全部楼层 |阅读模式
They won't be welded together or anything like that. Just sitting next to eachother embedded in concrete - part of my complicated DIY bathroom. ScottYeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
Reply:I've had brass threads gawl in aluminum on a number of occassions and I think there are other potential issues between the two if in direct contact with each other but ???  Google time.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Does this help answer your question?http://www.fastenal.com/content/feds...0Corrosion.pdfThere's a bunch more too.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:You nailed it Duane, concrete is alkaline and with Aluminum and Brass [Zinc-Copper] you’re building a battery and it will rot out in no time.
Reply:Thanks guys.I can tank the floor and isolate the aluminium from the concrete, but the brass and aluminium were going to sit next to eachother. I'll just go with the aluminium.ScottYeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
GMT+8, 2025-12-21 12:45 , Processed in 0.105934 second(s), 18 queries .
