Bar Stool Racer Project
发表于 2021-9-1 00:41:52 | 显示全部楼层 |阅读模式
I wanted to post photos of my first real welded production project that has actually been completed and works great!I spent about 6 weeks building this Bar Stool Racer.  I did all welding with a Lincoln Pro Mig 175 using FCAW.I would have to say the most fun on this new toy is riding wheelies down the street.Enjoy!Mike Attached Images
Reply:Here is a view from the back. Attached Images
Reply:I'm impressed.  Are there actual races for these?  I would think that sharp cornering would be somewhat of a problem.  What size engine does it have and how fast will it go?
Reply:Believe it or not, there are actual groups of people that race these things.  I used a 6.5 HP motor.  It is very fast and you really need to hang on when in the gas.  I am still afriad to open it up.  It is estimaed to go about 50 - 60 MPH in 8 seconds from the research I have done.I did not build it to race, but to be the first one in my neighborhood to have one.  Also when I go to the drag strip I wont have to walk 5 miles a day anymore. I have more detailed information if anyone would like at my web page: http://smartalich.com/barstool/Last edited by malich; 12-17-2004 at 10:03 PM.Build a Barstool Racer at BarFlyRacers.com!
Reply:Looks good. Can you post a site where you got your parts from. IE wheels, tires, hubs, axles, bearings, spindles, brakes and sprockets. I orderd plans already and they are not it yet. I guess the build sheet will tell me where to get the stuff but I want to see what other people are doing.  Thanks.     T.J. www.tjsperformance.com
Reply:Mike that is too much! Have A Great Holiday,Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:mike don't worry, it's not too much! actually my cousin and i are going to build two of these and we are going to use a briggs and stratten wazoom motor, and a wazoom shifter motor on them.   Those two motors top out at about 70 mph and we had to make some minor adjustments to it; such as lowering the stool down, and making the chassis wider so we don't have so many accidents.   we saw your picutre during a welding class one day and fell in love with the idea.  keep thinking of the good ideas.
Reply:Yes this post has me hooked now too. I ordered plans as well. I want to put  a 125cc motocross motor in it though and use a shifter as well. Should not be that hard to fabricate a shifter rod assembly so that I can operate it with my left foot. I would then need to make a pedal for the breaks in the rear. There is a cycle salvage place near me and getting a whole running KX 125 would be best cause I can use most of the control parts from it.  T.J.www.tjsperformance.com
Reply:Good looking BSR! I built one too, but someone just had to have it, so I sold it. Here is a link to the buildup. I didnt buy any plans, so it was just trial and error. It was a blast to ride. There are some vids on my site as well.Last edited by monkey-1; 12-29-2004 at 03:44 PM.-Monkey-1http://www.studmonkeyracing.com [email protected]
Reply:klosterman,You might also want to get your wheels balanced for that speed.  I get a vibration around 30 mph.Let's see some more designs for these bar stool racers.MikeBuild a Barstool Racer at BarFlyRacers.com!
Reply:Hey monkey-1,I liked your mpegs.  One thing I did not see is you riding any wheelies?  All mine wants to do is snatch the front end off the ground all the time, even in the back yard in the grass.Did you run a live axle on your BSR?Take care,MikeBuild a Barstool Racer at BarFlyRacers.com!
Reply:Originally posted by malich Hey monkey-1,I liked your mpegs.  One thing I did not see is you riding any wheelies?  All mine wants to do is snatch the front end off the ground all the time, even in the back yard in the grass.Did you run a live axle on your BSR?Take care,Mike
GMT+8, 2025-12-21 12:45 , Processed in 0.070152 second(s), 18 queries .
