查看: 13|回复: 0
weird smell while tig welding ? any help is appreciated please
发表于 2021-9-1 00:41:47 | 显示全部楼层 |阅读模式
Okay I have an older syncrowave 300 tig maching Ive been using it for about 3 years now Im not an expert welder by any means, I mostly use it for exhaust pipes, and misc fabrication parts I need to make to build the custom harleys that I do long story short I got a new profax torch the other day because I got sick of trying to find consumables for my old torch (it was a very old weldcraft torch)Im now noticing that Im getting a very bad smell which smells like gas or something like it it actually makes me almost want to vomit Ive never had this problem before Im using the same bottles with the same gas as I was with the old torch same tungsten etc. the only thing I changed was the torch and Im using a foot pedal now instead of the thumb switch I had been using the new torch has a gas knob on it but I have it just slightly cracked open I tried the gas setting on the torch itself in just about every range of motion and Im still getting that awful vapor like smell please can any help me out on this one im truly at a loss thanks
Reply:Is the smell coming from the torch or foot control?If from the torch, is it water cooled?If yes:1) Are the coolant lines hooked up correctly?2) Have you confirmed proper coolant flow from/to the cooler?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Is the smell coming from the torch or foot control?If from the torch, is it water cooled?If yes:1) Are the coolant lines hooked up correctly?2) Have you confirmed proper coolant flow from/to the cooler?
Reply:I'm not familiar with profax but could it be coming from the insulator(s) on the torch head when they get hot?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55I'm not familiar with profax but could it be coming from the insulator(s) on the torch head when they get hot?
Reply:Have you tried going back to the old torch for a few beads, to see if you still smell it?I have a Profax on my mig, that thing has been through hell 'n back and is still ticking.The soldering toys pay for the welding toys.Hakko 928 dual iron, 4xHakko 936Madell 850D Hot Air SMT ReworkMiller 252, HTP Invertig 201 AC/DC, and a Hypertherm 45.
Reply:the old torch is completely broken if the new torch was burning up anywhere wouldnt I feel it in the torch I removed the sleeve by the handle on the torch and the cable and gas line look brand new no signs of any wear or anything like that ? Im truly at a loss on this one again any suggestions are appreciated could it be something with the foot pedal ?
Reply:Maybe someone packed it full of Limburger cheese.I'm really at a loss myself on this one ralphiejantz.  Sorry that I haven't been more help.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:sounds  like you gotta call profax...
Reply:Do you keep brake kleen in your shop?  A spray anywhere nearby or on the torch or material will let off fumes.My name's not Jim....
Reply:New torch, right?Any chance there's a label on the inside of the gas cone thats burning?Tim Beeker.
Reply:Any chance it was made in China?Any paint on or near the torch head?That Chinese paint smells of something fierce, especially when it gets hot!Almost smells like burning hog manure. #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by Ken DennisAlmost smells like burning hog manure.
Reply:Have you found the problem yet?Tim Beeker.
Reply:I had a second bout of it in the same area, doc threw some really strong meds at it and its completely gone now and healed up nicely! Damn hogs! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Its gone away for now I just finished welding up some exhaust pipes and an oil tank over the weekend cant figure out what the hell it was I took the torch apart and it was clean inside I just changed to a new piece of tungsten, and it seems to have gone away,thanks for all the replys it still confuses me as to what it might have been but its gone for now so thats good enough for me
GMT+8, 2025-12-21 12:52 , Processed in 0.105477 second(s), 18 queries .
