6gr
发表于 2021-9-1 00:41:44 | 显示全部楼层 |阅读模式
Can anyone show me a wps for this please.  And and details as well please.
Reply:I have certified over 2,000 6GR welders with .045 E71T1/C-25. 8" Schedule 160  Pipe, with a flat cut, welded to an 8" schedule 80 with a 33 Degree Bevel, with a nickel Nose and a 3/32 Root opening.  200 Amps and 26 Volts.  Positioned in a 45 degree angle with the 180 pipe up. Root (up), fill (up) and 3 down caps.  Only 2 could not pass.  6 weeks course.  I will look for the WPS, but above is the same, just fill in the blanks.  John GaultSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
GMT+8, 2025-12-21 12:24 , Processed in 0.081035 second(s), 18 queries .
