School Project
发表于 2021-9-1 00:41:41 | 显示全部楼层 |阅读模式
Hi guy, Im a junior in high school and of course in a welding class. I've been welding for quite some time and its time to make a project. I was thinking of making a grill out of  a 55 gal. drum I have lying around in the shop. I was wondering if any of you have any ideas what to use to make the cradle and legs out of.I can stick weld, wire weld, oxy actylene weld (with or without a rod) and I  have access to a plasma cutter.
Reply:Originally Posted by RiesenbergHi guy, Im a junior in high school and of course in a welding class. I've been welding for quite some time and its time to make a project. I was thinking of making a grill out of  a 55 gal. drum I have lying around in the shop. I was wondering if any of you have any ideas what to use to make the cradle and legs out of.I can stick weld, wire weld, oxy actylene weld (with or without a rod) and I  have access to a plasma cutter.
Reply:Originally Posted by mwhaughtHere's a good, easy to follow plan for that project.http://www.lincolnelectric.com/knowl...ontent/bbq.asp
GMT+8, 2025-12-21 12:21 , Processed in 0.260781 second(s), 18 queries .
