Tig cart buildup
发表于 2021-9-1 00:41:38 | 显示全部楼层 |阅读模式
OK, here are the beginnings of a tig cart I am building. These brackets are for the rear wheels. I will add more pics to this thread throughout the build-up Attached ImagesLast edited by Planet X; 02-13-2004 at 10:39 PM."after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:Here is a little jig I use to keep spacing of brackets. The spring is from a Toyota 'f' motor and the bushing is just some 1"tube that I cut to the correct width-I added 1/8" extra width to allow for shrinkage- should amount to 1/16" on either side plus. Attached Images"after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:updates?
GMT+8, 2025-12-21 00:58 , Processed in 0.087406 second(s), 18 queries .
