Need 4" pipe fittings
发表于 2021-9-1 00:41:37 | 显示全部楼层 |阅读模式
I need a source for 4" pipe fittings, 90deg. with butt weld prep on both ends.  Needs to be an 8" radius. Sch 40 preferred, but thicker will be ok.I tried mcmaster-carr and some other usual places but they only have up to 6"Have we all gone mad?
Reply:Reliable Pipe Supply Co Inc(619) 233-01181430 National AveSan Diego CA 92113MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Snoe have you tried Hajoca on 63 near 202? I've gotten ductile Iron and SDR from them. Also there's 2 places  in the area we've gotten pipe from whose names I can't remember right now. One is in Horsham /Willow Grove on Blairmill Rd. just off 611, the other is just over the Danhour (sp) bridge after you cross Ridge going south on 202 in Norristown. Don't know if any of them carry weld fittings as thats not what we usually are getting, but just a thought since they are all sort of in your area...No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I don't know if it's just my region or everywhere, but all of the local steel supply houses and welding suppliers keep them in stock. Here in Texas, we make lots of pipe fence entries out of 4 inch.Kevin- Springtown, TexasTruck:Chevy cab/ chassis 1 ton dually, big block and flatbedMiller BobcatVictor cutting rigTool boxes crammed full of stuffShop:Millermatic 250Lincoln 135Lincoln 225AC tombstone
GMT+8, 2025-12-21 00:57 , Processed in 0.102885 second(s), 18 queries .
