查看: 13|回复: 0
Need Migmate Super schematic
发表于 2021-9-1 00:41:36 | 显示全部楼层 |阅读模式
The wire feed regulation on my Migmate Super wire welder is not very good. I need the schematic to isolate it from the weld loop. I want to use a small 24 volt transformer a diode bridge with capacitor to provide a more accurate wire speed. Any help will be very much appreciated.
Reply:Hi,searcing the forums for migmate info, I found your post. A bit late to reply now maybe  but in case you are still searching, I have just modified the wire-feed and gas-flow triggering on my migmate DP (gas/gasless) welder. I have added complete instructions on my website:http://hobbymechatronics.com/project...ess-mig-welderyou will also find the schematics there (I tried linking them to this post, but due to the width of the schematic image being much larger than the width of this forum, the forum-view got messed up (some of the text disappeared as it ended up outside the visible area of this forum).Bjorn--------------------------------------------www.hobbymechatronics.com
GMT+8, 2025-12-21 07:59 , Processed in 0.103576 second(s), 18 queries .
