Autocad 09'
发表于 2021-9-1 00:41:34 | 显示全部楼层 |阅读模式
How can I setup Point Style under Format to stay at the same settings for every drawing I open?  I couldn't find anything under options.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Make all changes to settings, then save the drawing as a template, then use that template everytime a new drawing is started.  (Existing drawings would remain as-is)Good luck.
Reply:Bummer.... I have to re-open a pile of drawings and have to change the settings every time.  Oh well..Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-21 07:48 , Processed in 0.068631 second(s), 18 queries .
