hey biker guys
发表于 2021-9-1 00:41:31 | 显示全部楼层 |阅读模式
on the frame i am planning, is a 2" downtube TOO fat??, i was planning on 1" tube for the rear areasStangnetShop Full Of Stuff. Joey
Reply:viper,If you're going to go to the trouble of building a bike, why wouldn't you use dual downtubes?  You'll get more rigidity and be able to flow those tubes right back to your rear wheel.
Reply:i was thinking about maybe havin the single tube arc down from the headset, then fork out into a dual tube at the first engine mount areaStangnetShop Full Of Stuff. Joey
Reply:decided on 1 3/4" sq. tube now i gotta buy me some expensive steel.....StangnetShop Full Of Stuff. Joey
Reply:i had thought about something unique... Stainless Sq. Tube.. then i thought about the price of it and the price of extra bits&blades to work it.... Steel Supports Me, So I Support Steel.StangnetShop Full Of Stuff. Joey
Reply:If you haven't already, check out www.chopperweb.netandhttp://64.172.168.34/neatstuff/index.htmlthat's the Chopper Builder's Handbook.  Very interesting and useful info for aspiring bike builders...
Reply:don't know if you want a soft tail or ridged frame.this site should help out on building your jighttp://www.mechwerks.com/MechWerks_plans_drawings.htm
GMT+8, 2025-12-21 08:56 , Processed in 0.313666 second(s), 18 queries .
