Truck bumper
发表于 2021-9-1 00:41:30 | 显示全部楼层 |阅读模式
Sunday a bud came by with his 98 Dodge one ton dually.  I built this bumper for him when he first got it new. Attached Imageslife is good
Reply:As you can see it's earned it's keep.  Here's a shot of the mounting underneath. Attached Imageslife is good
Reply:The other mounting plates. Attached Imageslife is good
Reply:When I built it I put a fold over section that came up over the hood similar to the Stinger set up on H-1's.  Bud didn't like it.  Said it made it look like an Aussie logging rig.    Yes.  It was powdercoated right after fabricating.  But even powdercoating isn't harder than a concrete pier in a parking lot.    He didn't hurt the bumper when he hit the light standard pier.  But he did break the power steering set up and some other pieces when the front end went sideways.  The Cummins is heavy.life is good
Reply:what did you use to bend the Big tube on the bottom? what is that 4"
Reply:Originally Posted by blacksheepwhat did you use to bend the Big tube on the bottom? what is that 4"
GMT+8, 2025-12-21 09:00 , Processed in 0.093544 second(s), 18 queries .
